5177 conversion to NX MAF ??
Old Apr 24, 2004 | 03:46 AM
PREDATOR-Z's Avatar
Default 5177 conversion to NX MAF ??
Can this be done?
What would be the parts needed??
Details please.
Thanks
Old Apr 24, 2004 | 09:38 AM
slow's Avatar
it can be done yes, but your better off, selling your old 5177 kit, and buying a maf kit.
It comes with better noids, and an electronic TPS switch for a super clean install.
you can probaly sell your 5177 for $400 or so, and pickup a maf kit for 800.
the maf ends alone, are $350 according to the other post around this forum, and that doesn't include the good nx noids, and the electronic tps switch.
Ryan.
Old Apr 24, 2004 | 11:33 AM
PREDATOR-Z's Avatar
Thanks Ryan,
That's what I thought.
I think I'm going to keep the 5177 and run a dual dry/wet systems.
Shoot 100 dry from start up and then a 100 shot wet as soon as I hit 2nd gear.
A little more expensive but I will benefit from a softer launch and go wicked after that.
Marc
Old Apr 24, 2004 | 01:13 PM
koolrayz's Avatar
I thought you could get the MAF kit in a 2 stage?
Old Apr 24, 2004 | 04:09 PM
PREDATOR-Z's Avatar
you can. But it will be a dual wet single system. I'm thinking dual systems. 1 dry & 1 wet.
Old Apr 25, 2004 | 05:15 PM
koolrayz's Avatar
Why not just convert your 5177 kit. I run 50 on the first stage and 125 on the second. I see more RWHP this way than others report using no jets
I saw 124 rwhp with 125 shot using the jet charts in the colonels nitrous tips and 145 rwhp on a 150 shot. I saw little peak hp gain when i went to the 175 pills but the HP curve ran much flatter and higher at the high RPM. I beleive many see reduced HP with the 5177 kit because it runs through 2 solenoids insted of 1. If you want to convert your system just run the inlet hose into the blocked off port of the solenoid connector. Then wire the solenoids as 2 seperate systems. I have one on the WOT switch and one on the window switch. That allows you to match to traction. IMHO
Old Apr 25, 2004 | 06:16 PM
PREDATOR-Z's Avatar
Ah yes, I see what u mean. Ingenious, thanks Ray. I think I might give this a shot before going wet.
Old Apr 25, 2004 | 06:18 PM
slow's Avatar
you will need injectors and tuning to spray that large of a dry shot.
Ryan
Old Apr 25, 2004 | 09:00 PM
koolrayz's Avatar
Ryan
And a bigger fuel pump. Ive been okay doing it with pump gas but im only running 24 degree's of timing
Old Apr 25, 2004 | 09:09 PM
slow's Avatar
pump is true, but any type of kit with those power levels needs a pump, so i was assuming he either had one, or was going to get one.
Ryan.
Old Apr 26, 2004 | 04:30 AM
PREDATOR-Z's Avatar
I have a Walbro, and I tune with Predator. I ain't worried about gas, premium here is 98 octane
With no jets, I'm at 28* timing with TR6's and no KR.
I'll probably have to go with 26* for the dual stage.
Old Apr 26, 2004 | 07:25 AM
koolrayz's Avatar
[QUOTE=PREDATOR-Z] I ain't worried about gas, premium here is 98 octane QUOTE]
Must be nice 94 is tops for unleaded pump gas here. Unless you buy buy the drum
Old Apr 26, 2004 | 09:17 AM
PREDATOR-Z's Avatar
Can't u still get race gas at UNICAL 76?? That's where I used to go to, next to the tiny airfield in Toledo during my old racing days at Norwalk.
Old Apr 26, 2004 | 01:24 PM
koolrayz's Avatar
toledo is a pretty good drive for me, It would be easier to buy the drums.
