Bottle heaters
Old Apr 30, 2013 | 04:22 PM
SuperSlow02's Avatar
Default Bottle heaters
What's everyone's preference between pressure switch and thermostat? Is there a noticable difference between the two? Nitrous will only be on the car till the end of the year so I'm looking to spend as little as possible...lol
Old Apr 30, 2013 | 04:31 PM
HCI2000SS's Avatar
Well the pressure switch also controls the temp. Maybe i'm not following what you're saying here lol
Old Apr 30, 2013 | 04:44 PM
Which one maintains pressure best between the two different set ups? I would almost think the thermostat would shut off quicker as it would read of the surface temp of the tank.
Old Apr 30, 2013 | 04:50 PM
Nitro Dave's Nitrous Outlet's Avatar
I am concerned with pressure more than I am temperature. The pressure switch is also more reliable as the thermostat. The thermostats always seemed to burn out over a perioud of time.
Dave
Old May 1, 2013 | 06:35 AM
I wasn't actually concerned about temperature, just didn't know if there was a noticeable difference between the two styles in maintaining pressure.
Old May 1, 2013 | 09:04 AM
JDEP162's Avatar
Dave
dave, my kit from u shud be in today, this poses a question related for me too, what will my heated bracket come with, pressure or thermostat?
Old May 1, 2013 | 09:22 AM
brandon@nitrousoutlet's Avatar
Pressure.
Old May 1, 2013 | 09:46 AM
ss performance's Avatar
Pressure switch is the best way to go.
Keeping the pressure constant allows you to be more consistant. As the nitrous level drop from use the heater will raise the pressure to the preset level.
ARC Heat in Daytona FL makes an adjustable pressure switch.
Good luck
Old May 1, 2013 | 09:58 AM
Thanks, I was figuring the pressure switch would be the better way to go.
Old May 1, 2013 | 10:25 PM
JDEP162's Avatar
Originally Posted by brandon@nitrousoutlet
Pressure.
my kit came today,its like santa clause drives a ups truck. awsome brandon thanks, updates asap
Old May 1, 2013 | 10:27 PM
HCI2000SS's Avatar
So what kit and heater did you go with?
Old May 2, 2013 | 03:23 AM
roninsonic's Avatar
pressure switch, all day every day.
Temperature switch always seems retarded, to me. Bottle pressure will vary at the same temperature depending on the amount of nitrous in the bottle.
