What did you use to cut your lid?
Old Oct 12, 2002 | 08:17 AM
SPANKY LS1's Avatar
Default What did you use to cut your lid?
For those of you who had to cut some off of the "neck" of your lid, what did you use, and did it cut easily? I'm thinking of just using my sawsall, will this work well? TIA, Shawn
Old Oct 12, 2002 | 08:33 AM
DriveATransAm's Avatar
Default Re: What did you use to cut your lid?
<img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Oct 12, 2002 | 08:38 AM
SPANKY LS1's Avatar
With the SLP 85mm MAF, the MAF won' fit down in the lid like the stocker did. This makes the maf sit back ~1.5", which makes the bellows sit back ~1.5", etc. The stock bellows is jammed in there, the SLP bellows won't even fit. I either ned to cut down the bellows or the lid, not sure yet, bellows would be easier and more forgiving, but....
How do you like the new mod? Any SOTP difference? I'll call you later, Shawn
Old Oct 12, 2002 | 09:18 AM
you shouldnt need to cut anything. ill show you how mine is- you need the thing to go OVER the lid, not in it with a larger maf.
Old Oct 12, 2002 | 09:20 AM
oh yea, it feels pretty good so far...ill be able to tell a little better today if its not wet out <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Oct 12, 2002 | 02:00 PM
Z06PSI's Avatar
Used a dremel. worked like a charm even clean cut.
