Newbie Nitrous Question
Old Oct 12, 2002 | 01:44 PM
BYBYC5's Avatar
*Bad Trader*
Default Re: Newbie Nitrous Question
150 will be ok, but your gonna get alot of diffrent opinons on this matter, im speaking from lots experiance with spray that you should be ok if you tune properly and take care of your plugs and dont assume anything, always check and if you second guess somthing dont spray....
Old Oct 12, 2002 | 01:53 PM
383LQ4SS's Avatar
What kind of mods do you have and what year is the car?
Also check the sig for The Colonels N20 tech files for some goo basic info.
<small>[ October 12, 2002, 01:59 PM: Message edited by: 383LQ4SS ]</small>
Old Oct 12, 2002 | 03:15 PM
Josh Johnson's Avatar
I have a 2001 M6, pretty stock with exhaust, lid, and pullies.
Old Oct 12, 2002 | 04:35 PM
PewterZ's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Josh Johnson:
<strong>I have a 2001 M6, pretty stock with exhaust, lid, and pullies.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">With that car...all you need is a "colder" set of plugs and the kit installed safely and correctly....most nitrous guys use the NGK TR6'S.
I think I would just run a 100 shot on that car and have no worries at all. IMOP. Its a blast man go for it.
Old Oct 12, 2002 | 04:42 PM
Would I need to get some tuning done? I don't have LS1 Edit, nor do I think I would necessarily have the skills to use it. I've never seen it, but I don't doubt that there would be parameters of tuning involved that would be well beyond my Automotive know-how, which is mediocre at best.
Josh
Old Oct 12, 2002 | 04:43 PM
Also if someone wouldn't mind taking a minute to teach me how to put in a "sig" i'd a appreciate it.
Josh
Old Oct 12, 2002 | 06:07 PM
SSDriver's Avatar
<strong>Would I need to get some tuning done? I don't have LS1 Edit, nor do I think I would necessarily have the skills to use it. I've never seen it, but I don't doubt that there would be parameters of tuning involved that would be well beyond my Automotive know-how, which is mediocre at best.
Josh</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You don't need any tuning, I would however make sure your car is not running lean at all(this could cause some seriouse damage). Also do NOT run HPP3 power tuning or any type of device that advances your timing(SLP air temp module, timing ticker, etc).
To add a sig click the PROFILE button on the top of this page. Then click "View/Update Profile" and you can make your sig there. PS. before adding a reply or making a post you must check the box that says to include a sig.
<small>[ October 12, 2002, 06:08 PM: Message edited by: SSDriver ]</small>
Old Oct 13, 2002 | 12:49 AM
Default Newbie Nitrous Question
Im giving serious consideration to a wet kit right now, and Im wondering how big of a shot you can run on the stock fuel pump? I'm a major nitrous newbie, never even considered it until a few days ago, so any tips anyone can give would be very much appreciated.
Thanks a lot in advance.
Old Oct 13, 2002 | 07:00 PM
Well, I believe ive pretty much made up my mind to go with a Wet Nitrous Kit. So I guess what I need to know now is, Is one kit (say NX or TNT, ect.) better than any other? Im getting mixed reviews from all directions
Some people I read say get the TNT kit but get certain components from NX or vice versa. And what about a Window Switch since Im an M6? What components don't typically come with the kit that would be absolutely necessary?
Thanks a lot for everyones help so far!
Josh
Old Oct 13, 2002 | 08:28 PM
SSDriver's Avatar
<strong>Well, I believe ive pretty much made up my mind to go with a Wet Nitrous Kit. So I guess what I need to know now is, Is one kit (say NX or TNT, ect.) better than any other? Im getting mixed reviews from all directions
Josh</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">If you want to run consistintly go with an NX bottle heater it actually heats up the bottle to its REAL pressure.
With an M6 definitly go with a window switch it will save your motor incase you mis shift and it makes things a lot easyer. If you want a TPS switch or a remote bottle opener I would definitly go with NX. Oh yeah I would also get a N2O filter.
As for the main kit go with NX or TNT and you should not have any problems.
Old Oct 14, 2002 | 11:42 AM
F.A.T. PERFORMANCE 01's Avatar
definetly run a window switch. it would be the only thing that saved youre engine if you over rev.
