HSW Nozzle with NOS jets?
Old May 8, 2013 | 07:12 PM
JoeMama's GTO's Avatar
Default HSW Nozzle with NOS jets?
Can NOS jets (thin stem) be used with a Harris Speedworks Sudden Impact single nozzle? Seems like if the jet bottoms out it should be OK as the perimeter is sealed. Thanks for the help.
Old May 8, 2013 | 07:14 PM
HCI2000SS's Avatar
Well I know NOS jets won't work with a NX kit, so it very well may not with yours too.
Old May 9, 2013 | 09:25 AM
PuruJones's Avatar
Ive done the opposite, HSW jets (wider) into a NOS plate which uses the skinny jets.
by dremeling the fitting so the jet can slide into it, and it works. in theory, the line should center the jet in the fitting and should be ok.
Old May 9, 2013 | 10:36 AM
brandon@nitrousoutlet's Avatar
I think HSW uses NOS style jets.
Old May 9, 2013 | 11:58 AM
camscam02's Avatar
HSW used the same jets that Nitrous Outlet and Nitrous Express uses. Thick short stem
As for the OP I think the head is the same with the difference in the stem as you stated. Not sure if it will work
Old May 9, 2013 | 12:00 PM
Well....there ya go.
