What is a Window Switch
Old Oct 18, 2002 | 12:51 AM
CAT3's Avatar
Restricted User
Default What is a Window Switch
I am taking that it basically times the activation of the N2O based of from minimum rpm's set by pills, e.g. 3000 and 6400 meaning the first stage sprays at 3k and the second at 6.4k or is it only spraying from 3k to 6.4k? TIA
Old Oct 18, 2002 | 06:10 AM
phil46y's Avatar
Default Re: What is a Window Switch
You've got it. The intent is to keep the N2O from being sprayed at to low RPM or into the rev limiter.
Old Oct 19, 2002 | 12:55 AM
CAT3's Avatar
Restricted User
Thanks Phil. Do these require me to put more switches in the car, or is it tapped off the arming switch? TIA.
