stock pump with voltage boost?
Old Oct 22, 2002 | 09:34 AM
boomcase's Avatar
Default stock pump with voltage boost?
Has anyone just installed a voltage boost(boost a pump) on there car for running a 150 or higher shot of nitrous. ANYONE.
Old Oct 22, 2002 | 10:49 AM
nysbadmk8's Avatar
Default Re: stock pump with voltage boost?
just spend the 150 bucks for a walbro 340... no boost a pump i know of that would safely allow you to run more then 150
Old Oct 23, 2002 | 05:03 PM
DONAIMIAN's Avatar
I wouldnt try it, too big of a chance that you would either burn your pump out from too much voltage(or a voltage spike), or (wich will most likley happen is you shorten the life of you pump and it goes out when you a lond *** way away from home. Either way I wouldnt try it, even if i got it for free to be a test dummy for it, but your car do what you want. <img border="0" alt="[kaboom]" title="" src="graemlins/gr_bomb.gif" />
