Need help with HSW Interface
Old Jun 21, 2013 | 03:18 AM
02TransAm/Batmobile's Avatar
Default Need help with HSW Interface
OK, I purchased a HSW Interface two years ago and I'm getting ready to install it - I know, I'm slow as hell. Anyway, I purchased the Interface because I am going head/cam soon and would like the best NA tune and pull timing only when I spray. Now I'm reading over the instructions and If Im reading this correctly, I can only pull three degrees?? How did I miss that when I purchased this thing?
This is for an LS1 application. Any help is much appreciated because I don't think I have enough funds to convert this into a wet system.
Old Jun 25, 2013 | 03:39 PM
Bump. The Nitrous section has died a bit it seems.
Old Jun 25, 2013 | 04:44 PM
Nitro Dave's Nitrous Outlet's Avatar
I see your post but I can not help you. Its been so long since I have seen one of them I can not remember much about it.
Dave
Old Jun 27, 2013 | 10:23 PM
Dave
Appreciate it. Bump. Anyone?
Old Jun 28, 2013 | 09:33 PM
john563's Avatar
i think you can hook it up to hp tuners to pull more timing..i have 4 pulled with my 100 shot
Old Jun 29, 2013 | 03:28 PM
TA1364's Avatar
If I remember right 3 degrees is the default for when the IAT is maxed out, which is what the the interface does. It can pull more but the values for the temp range it defaults too need changed.
Old Jun 30, 2013 | 01:03 PM
john563's Avatar
thanks for sheddin some light on that sam
Old Jul 10, 2013 | 01:30 AM
ironhorse583's Avatar
i have the instructions i can email u...any1 need/want them just send me a pm with ur email..
Old Jul 18, 2013 | 01:18 AM
All this tuning jargon flies right over my head - I don't know diddly squat about this type of stuff. I will be taking my car over to Straightline Performance for the tune. So pulling more timing is possible but more complicated?
Appreciate it but I have the instructions. I thought you could pull timing on the controller itself (you can pull only 3 degrees on the box) and didn't know for more than three, you had to manipulate this through a tuning device which is why I created this thread.
