O2 Sims and NX
Old Nov 6, 2002 | 08:26 PM
Ravenous T\A's Avatar
Default O2 Sims and NX
I was wondering if my O2sims may cause a problem when I spray. If I run a A/F gauge, what else would I need to run it safely. Should I hook up the O2 sensors when I spray or are they not needed.
<img border="0" alt="[Firebird]" title="" src="graemlins/formula.gif" />
Old Nov 6, 2002 | 09:06 PM
xaon's Avatar
Default Re: O2 Sims and NX
O2 simms are used on the rear o2 sensors only when you are not running cats. They do NOT effect the A/F ratio WHATSOEVER.
Run nitrous safely. Fuel Pressure Safety Switch, WOT switch, and a window switch if you have a 6speed.
