Fuel Pressure Switches
I have the system wired correctly to allow this to work... two relay's (one per solenoid) which has the fuel come on... and then the nitrous is wired to come on after the pressure in the line gets to 50psi.
Should the switch work in this fashion?????
Personally, when i do installs, i run them before the fuel noid, and just one relay, to power both the noids.
have never had a problem in the setups ive worked on.
Ryan <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
