WOT switch on a vette
Old Nov 20, 2002 | 04:04 AM
G5TA's Avatar
Default WOT switch on a vette
I was wondering how you would wire it up on it since its fly by wire?
Old Nov 20, 2002 | 08:07 PM
C4VetteLS1's Avatar
Default Re: WOT switch on a vette
our shop sells a bracket that mounts the wide open switch under the pedal. there is a bolt with a nut on it you remove and just put it back in and screw the wot switch to it, quick 5 minute install.
Its $50 bucks.....other people have different ways you may try. but this is pedal WOT activated.
Old Nov 21, 2002 | 12:07 AM
ZEIK 383's Avatar
The Vette does in fact use a drive by wire. The easiest way to do this is to use a throttle position sensor switch. I used a TNT kit on ours and the switch was included in the kit. NX also makes one of these which I have also used; both work equally well. The NX switch is part #15961 I think. They sell for around 100.00 to 150.00 depending on your source. Check with either company, they will help you out. I hope this helps.
Old Nov 21, 2002 | 02:02 AM
G5TA's Avatar
Thanx guys .I'm going to go check with TnT becasue i live about 10 mins away from them and i know Tony and Jamie there i should have went up there and talked to them but i havent had the time.
