When do you need bigger Injectors
Marco
What mods do you have now?
I'm not sure exactly when you should upgrade your fuel system. I'm fairly sure a stock fuel pump and injectors can't handle 500rwhp. You might want to upgrade to a Walbro in-line pump and bigger injectors just to be on the safe side.
Like I said though, I'm no expert.
<small>[ November 20, 2002, 08:45 AM: Message edited by: Paul @ Thunder ]</small>
<strong>Are you going with a wet kit or dry kit? The stock 28lb injectors should be good for the motor alone and if you are using a wet kit then it's not going to put any more load on the injectors, just the fuel pump. If that the case then all you'll need to do is upgrade the fuel pump and you should be fine. If you are doing a dry kit then you will need bigger injectors and a fuel pump. The stock fuel system is good to about 450rwhp. Hope this helps.....</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks Paul Thats what I needed to know. I guess now its time to find the right fuel pump for the job.
Marco
