n.o.s ,what do i need to do?
Old Nov 22, 2002 | 04:36 PM
mike c.'s Avatar
Default n.o.s ,what do i need to do?
i have a 01,ws.6-m6.i have all boltons,heads,hammer cam,12bolt 3.73's(am switching to 4.10's)425 rwhp and 408 rwtq,i want to use a t.n.t kit what do i need to change to run this kit with NO problems? do i need to re-re program the computer, ls1 edit? thanks, mike c.
Old Nov 27, 2002 | 02:09 AM
383LQ4SS's Avatar
Default Re: n.o.s ,what do i need to do?
Your going to use a wet kit( im assuming?)...really youll just need an intank fuel pump and take it to a dyno to check AF. A way to control timing such as the Ramchargers timing box may be helpful since you will be pushing some serious HP as well. Also at that HP level Id use a window switch to ensure its not activated too low or revs into the rev limiter.
If its dry...youll need injector upgrade, fuel pump, computer reprogram as well as the above items.
Old Nov 27, 2002 | 09:36 PM
mike c.'s Avatar
well then....a t.n.t. wet kit it is. thanks for the help. mike c.
