have a question about my ses light going on???
Old Nov 26, 2002 | 12:26 AM
jeff's Avatar
Default have a question about my ses light going on???
i just got the nx wet kit and i installed it, i also have a pressure gauge, and i put on the window switch with the pills 3000 rpms to turn the nitrous on and have the 5800 for it to turn off. i got the bottle to 1100 psi, then i took my car for a spin. i was at a light and just wanted to test it out (i have used the nitrous before). and i put it in first slowly rolled then armed the switch and floored it! as soon as it hit 3000 it hit hard, for a 75 shot. and as i was shifting from first to second it spun so bad going into second that it hit the rev limiter, and as soon as it did that my ses or service engine soon light went on. i drove it back to my friends and restarted it. still on. woke up the next day. started it. still on. woke up the day after that. then it was gone. what could have caused this??? the light is off and has been off for a day now. do i have anything to worry about???. i dont know how anything could have gone wrong. i have the window switch set up for exactly that problem. ANY SUGGESTIONS OR COMMENTS???? thanks
1998 Trans Am WS6 M6
Borla, Lid, Mac Headers w/offroad Y-pipe (02 sims)MAFT, Nitto 555R DR, NX Wet Kit (75 jets), MSD Window switch, MSD wires, NGK TR6 plugs, SLP Air Temp Module, !MAF, !EGR.
Old Nov 27, 2002 | 01:47 AM
383LQ4SS's Avatar
Default Re: have a question about my ses light going on???
I believe the SES light will go out after three start cycles if the problem is not constant. So whatever threw your code was momentary, probably related to your hitting the rev limit. Its staying out...indicating all is good atleast as far as sensors are concerned. Should be ok <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Just stay off the limiter. <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
