NOS 5177 quick installation question
Old Apr 29, 2004 | 11:48 PM
Camaroguy's Avatar
Default NOS 5177 quick installation question
When installing the FPSS. What exactly do i need to do? The instructions arent clear enough for me to understand.
Can somone clearify for me.
Do i need to bleed the fuel rails then just put some lock tight onto the threads of the FPSS and screw it into the Fuel Rail, and thats it? Or do i take something or put something into the fuel rail before i put on the fpss switich.
Thanks
Old Apr 30, 2004 | 07:49 PM
Camaroguy's Avatar
Yes that helped. Thanks
Another question i had was about the wiring.
Hooking up the Amring Toggle Switch i need to top the Ignition Switched 12 Volts? Do i find that on the PCM?
Also for the MSD window switch. It says Tach Wire on PCM. What color is that?
Then for the Purge Swtich it just says 12 volts.... Do i also hook that up to the Red Wire on the PCM? Since thats usually 12 volts.
For grounding everthing... Do i hook it up to anywhere i can find a ground on the car or do i run all the wires to the negative end of the battery?
My car is an 02 SS M6
Thanks
