5.3 cam and nitrous only
Old Jul 31, 2013 | 10:20 PM
ls280z's Avatar
Default 5.3 cam and nitrous only
no head work stock rod bolts head bolts gaskets and everything. How fast have yall been. just with cam and nitrous?
Old Jul 31, 2013 | 11:07 PM
boostit5.3's Avatar
first time i went to the track i ran 12.9 on motor and 11.8 @ 119 on a 150 shot (didnt spray out of the hole, still hurt the rear)... at the time i had 3.73 rear gears but i broke my rear and had to swap in another that had 2.73s. i took it back to the track this past friday and it went the same 11.8 @ 120 on a 200 shot. im happy with it its pretty quick on the street i plan on finding some 3.23 or 3.42 gears, they should be a good middle ground because i was running out of gear in the 1/4 with the 3.73s.
Old Aug 1, 2013 | 03:51 PM
MustangLS's Avatar
LS6 intake, MS3 cam, comp valve springs, 88k mile 5.3L with a 200 shot. 94 Mustang 3150lb race weight.
9.85 @ 134.74
Old Aug 1, 2013 | 05:12 PM
01 4.8's Avatar
How much does your car weigh
Old Aug 1, 2013 | 05:22 PM
ls280z's Avatar
Default 76 280z
My car 76 280z. completly stock 5.3 with lunati 585 cam tooley valve spring kit stock ls1 intake. 2910 race weight 1.76 powerglide tight nitrous convertor 3.50 gear with 9" ford 230 shot dry with stock e85 28 lb injectors. havnt ran the quarter mile yet but managed 6.11 @ 112 with 1.35 60ft.
Old Aug 1, 2013 | 06:43 PM
Jarred Hodges's Avatar
what does it run on motor
Old Aug 1, 2013 | 06:51 PM
ls280z's Avatar
you really want to know lol 8.74 @83mph 2.0860ft
Old Aug 1, 2013 | 08:08 PM
boostit5.3's Avatar
im a full weight 98 z28, plus im a big guy.... so prolly close to 4000 pounds maybe more. going from a 3.73 to a 2.73 rear gear really killed me i expect low 11's with a 3.42 rear gear. also when i went to the track this past friday it rained right before the track opened so it was hot and muggy not ideal running conditions.
 Michael S. Palmer
Old Aug 14, 2013 | 10:29 AM
BSmiff's Avatar
That thing is cruisin for what you have done to it.
Old Aug 14, 2013 | 11:18 AM
Killer5.3's Avatar
Had a sbe 5.3 ,77,000 miles out of 04 tahoe in an S-15. Not sure on raceweight, only weight reduction was wheels, a/c, heat, sway bar, fiberglass bolt on hood, but put some heavy touring leather bucket seats and 160 lbs driver.
Mods :
carb swap
vic jr
Wilson Plate 73N/73F on 6.5 psi / 9 degrees pulled from 35 total
218/220 .535 lift cam 112 lsa
shorty headers
3in flowmasters w/ turn downs
th350
PTC 10 in 3800 nitrous converter
built 10 bolt with 3.73
Comp eng 90/10 front shocks
Rancho Rear shocks
Caltracs bars
275/60-15 MT Drag Radial
7.90 -8.0 @89 /12.30-12.40 @112 Motor
1.65 /6.70 @106/ 10.30 @130
6700 shift points leaving on motor and bringing kit in about 1-2 lengths out.
I had ordered some jets from Wilson to dial the tuneup in because it was still rich as eveident by the plug readings and backhalf mph, but, somebody wanted the truck worse than I did and sold it before I had a chance to. The guy that bought it from me didn't change tuneup, but , did leave on the kit several passes before breaking rear and went 1.38-1.40 / 6.40's 1/8.
Old Aug 14, 2013 | 02:17 PM
01 4.8's Avatar
Mods :
carb swap
vic jr
shorty headers
th350
Rancho Rear shocks
Caltracs bars
Nice passes, I'm ready to spray my 5.3 camaro
Old Aug 15, 2013 | 10:06 PM
86_irocz-28's Avatar
9.85 @ 134.74
1/4 or 1/8 mile?
Old Aug 15, 2013 | 11:38 PM
lsxnotch's Avatar
Originally Posted by 86_irocz-28
1/4 or 1/8 mile?
1/4 mile...
Old Aug 16, 2013 | 02:50 PM
MustangLS's Avatar
1/4 or 1/8 mile?
It went 6.23 @ 109 in the 1/8
Old Aug 16, 2013 | 03:42 PM
klutchkaaa's Avatar
nice!
Old Aug 16, 2013 | 04:20 PM
streetknight2's Avatar
I still can't believe how quick the Datsun is Clay. Post the pick up from last week
Old Aug 20, 2013 | 07:58 PM
ls280z's Avatar
Default youtube wheelstand vid
for some reason it wont post the pic but here is the youtube link pic shows how high it actually was sucks it wont load.
Old Aug 20, 2013 | 08:01 PM
ls280z's Avatar
Default Local 275 radial race. this was with the old 3:50 gear
Old Aug 30, 2013 | 10:16 PM
screamin88's Avatar
My 5.3 cam only RX-7 has gone 12.2 @ 112 with a 1.67 60' on motor. I have yet to get it to the track with the 150 shot. It went 11.8 @ 119 with a plugged nitrous filter. I put in a wideband and found I was pig rich. Then I found the plugged filter, put a new one in, and holy cow! It really pepped up when it got nitrous! LOL. I'm curious to know if I could expect a 10.90 or so in my 3000 lb Mazda?
Old Sep 7, 2013 | 02:30 PM
b00sted's Avatar
5.3, MS3-ish cam, ported 243 heads, Victor Jr, 750 carb, and a 175 shot. Went 9.7x in an average weight fox body. That was with very little tuning done. It had more in it if we would have played with the tune and suspension.
