WILL MY MOTOR LIVE?!?!
Old Dec 6, 2002 | 07:48 PM
VipZ28's Avatar
Default WILL MY MOTOR LIVE?!?!
hehe hope that got your attention.Ok to the point, my 100% bone stock motor has 74204 miles on it. 30PSi of oil pressure at idle, burns NO oil. Will it live with an NX wet 100 shot? usedfrom 3500-5500ish? I don't need it to live for ever, just about 6 months, and it won't be sprayed often, i'm to lazy to fill a bottle <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> I'm jsut wonder if it will even take the first shot! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Dec 6, 2002 | 08:06 PM
EVIL's Avatar
Default Re: WILL MY MOTOR LIVE?!?!
i dont see why not. nx 100 wet shot is pretty safe. will other parts other than the engine hold up....who knows. is it a m6 or a4 car? running etstreets or drag radials?
Old Dec 6, 2002 | 08:09 PM
VipZ28's Avatar
M6, on nittos, I won't be spraying until 2nd gear. rolls only, no digs <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> hehe i just mainly want it for my amusement, I am doing a lot of chassis work, because that will be set up before a built motor goes in it... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Dec 7, 2002 | 12:39 AM
CAT3's Avatar
Restricted User
Miles and condition of engine is not a positive correlation. You can grenade a 2000 mile car with nitrous if your running lean. Check your O2 readings first, especially with a 100shot. Ported MAF's are reportedly running leaner than stock, and there are other factors too so safer or sorry you choose. Next, if your wanting to spray, I assume you have listened to the engine for obvious precursors of detonation/bearing failure etc.... Good-Luck.
Charlie.
Old Dec 7, 2002 | 12:50 AM
VipZ28's Avatar
I pulled the screen out oy my maf and thats about it, yes i've looked at the motor, it has always, and continues to run just a bit on the rich side, no detonation, in the heat of the summer i only got 1-2 degrees of knock retard under WOT, fuel pressure is good, no knocking sounds yet <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> even piston slap is minimal at startup. Still runs just as strong as it always has, I think it will be OK, as i said I won't spray it much, I'm too lazy to fill the bottle <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Just wanted sone 2nd opinions!
Old Dec 7, 2002 | 08:31 AM
EVIL's Avatar
i used to run a nx 100 shot on bfg's on the street, like you said from a 2nd gear roll. it was a blast! i had a ported maf, and my car dynoed richer than on motor with a nx 100 shot. made 434hp/590tq with bolt ons. i ran it once at the track like that and hit the switch as soon as i felt it grab in 1st gear and ran a 12.03 @ 121. the stock clutch will hate you if thats what you are going to run. my z06 clutch would not engage hard on nitrous gear changes.
good luck, i think you will be fine, just check the atap readings and maybe wide band it on the dyno.
<small>[ December 07, 2002, 08:32 AM: Message edited by: EVIL ]</small>
Old Dec 7, 2002 | 08:35 AM
VipZ28's Avatar
What year model LS6 clutch did you order? I have the 2002 model, and it grabs pretty damn well... held a 4000 rpm DUMP at the track, with traction, and holds powershifts into 5th just fine (chirps the nittos actually) <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> I won't be powershifting on the N2O, like I said it's mostly just for my amusement until after I get the chassis set up <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Blane
