125 Shot on Stock 2000 TA
Old Dec 8, 2002 | 02:51 PM
y2kta's Avatar
Default 125 Shot on Stock 2000 TA
I have a stock 2000 Trans Am and I've read all the post on running(NOS)125 dry. It says that should be the MAX that I should go with stock fuel system. I know about the NGK TR-6's but what else would I need and do u think that is safe?
Old Dec 9, 2002 | 12:27 AM
CAT3's Avatar
Restricted User
Default Re: 125 Shot on Stock 2000 TA
Dry I wouldnt spray over 100. Wet, you can get away with 150, but just like 125 dry, your rolling the dice on a stock fuel system. Check this out, last night my friend sprayed 150wet, in a two stage setup and ..............something happened. Not sure yet, but I did replace his #5 plug on scene, the whole elctrode was gone, engine still ran rough and SES light still on. Anyway, he has been spraying that combo for like a year, and all it takes is the wrong juju and bam, onto the tow truck it goes.
I currently spray NX 100wet, no problems. If you still wanna do the 125dry, check fuel pressure, O2's (A/F), timing, and all that with autotap. Cross your fingers and hope it all ends well. Good-Luck.
Charlie.
