Adding a 2nd Stage
Old Aug 27, 2013 | 10:19 AM
FoHawk's Avatar
Default Adding a 2nd Stage
Currently I'm running a
  • Nozzle; 150RWHP shot
  • Standalone 7PSI (116 octane, cause it makes me sleep at night)
  • Window switch
  • WOT switch
  • AFR Gauge (sensor on passenger side collector)
Regardless of my RPM settings, I cant get 150 to hook on the 555rs I have. Yes... Im getting MT ET II's but even so I want to use a dual stage to be easier on the transmission and other components.
My buddy just gave me a dual stage plate for free, so what the heck. Im gonna get another set of noids and plum the fuel off the standalone into the 2nd fuel solenoid and use a T fitting to plum into the already existing nitrous line. Only problem is, I dont really understand how to install the noids to the Window Switc, so my plan was to just run the 75shot off the line with the noids already hooked up to the window switch and just run the 2nd stage (150shot) off of a button (have done this before, I completely understand its risky and that I must not engage before 3K RPMS)
I just think thats the easiest route to traction besides the new tires.
Also, I have a 15lb bottle that I use, but I have another 10lb bottle that I could use as a spare or... I was thinking about using another T to put both bottles on the same line but wasnt sure if that was a no-no or what.
Comments or concerns?
Old Aug 27, 2013 | 10:25 AM
brandon@nitrousoutlet's Avatar
You could run the button or get a Window Switch that controls 2 stages? http://www.nitrousoutlet.com/electro...ow-switch.html
Old Aug 27, 2013 | 10:44 AM
FoHawk's Avatar
I have that exact one Brandon, just dont understand how to wire it. Im a simple man
Old Aug 27, 2013 | 02:00 PM
Pm me your email address and everything in your system and I might have a diagram for it.
