progressive controller
Old Aug 28, 2013 | 01:41 PM
stherngent's Avatar
Default progressive controller
What's a good progressive controller? Spraying 100 shot, h/c/I , wanting to spray more and spray some off the line, I have a 9" rear end. What would be a good progressive controller to get. Thanks
Old Aug 28, 2013 | 02:03 PM
brandon@nitrousoutlet's Avatar
This is the NOS Mini Progressive. It also has a built in window switch and TPS. http://www.nitrousoutlet.com/electro...ontroller.html
Old Aug 28, 2013 | 02:13 PM
Brennen's01SS's Avatar
I just finished installing the mini, pretty simple install with clear directions. I haven't had a chance to use it yet but have read through the setup and seems simple enough to setup. From what I gather its pretty similar to the discontinued FJO mini , which had good reviews
I will be using it for the same reason (wheel spin) except I don't think I'll be spraying off the line with my 6spd. Maybe a second delay at 25% (150 shot) ramp for a 4-5 seconds to 100% after 3rd
Old Aug 28, 2013 | 02:17 PM
stherngent's Avatar
Sounds good, my system is already hooked up with tps and window switch, would I need to take those off and install the controllers tsp and window switch.
Old Aug 28, 2013 | 02:19 PM
edub80's Avatar
Put good tires on and I'm sure it will hook with a 100 out of hole..
Old Aug 28, 2013 | 02:33 PM
Yes. It should tap into the same locations.
Old Aug 28, 2013 | 05:08 PM
stherngent's Avatar
Ok thanks
