TNT 150 shot, H & C >10.5:1 CR....
Old Dec 20, 2002 | 12:41 AM
Phil99vette's Avatar
7 Second Club
Default TNT 150 shot, H & C >10.5:1 CR....
Anyone spraying a TNT 150 shot ontop of a H & C 346?
Phillip
Old Dec 20, 2002 | 01:42 PM
beardWS6's Avatar
Default Re: TNT 150 shot, H & C >10.5:1 CR....
I`m spraying 100 shot(TNT Wet) on mine. You can see in my Sig what I make. I have a in-line T-Rex fuel pump and 30lb injectors. I Love it! My timing is set at 23 degrees for safety. I loose a little N/A power with this but it is better on your motor. Being a A4, stall,12-bolt eats some up also. You need the fuel to support your set-up. The stock fuel system can only handle 400-450rwhp. Anything after that and you pushing it bad. So please up-grade. My bottom is stock also. You will not be upset with the way you will run <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> Good Luck!
Old Dec 21, 2002 | 12:46 AM
2000 Camaro SS's Avatar
I have done 100 no prob cept this..
http://groups.msn.com/RichardsBruce/benttorquearm.msnw
And a blown head gasket..
I then installed an inline fuel pump and this next summer I'm going with a 150.
