nitrous fuel pressure shut off
Old Dec 26, 2002 | 10:41 PM
rocketsled's Avatar
Default nitrous fuel pressure shut off
how safe it this switch. on 5117 and how could i make this kit safer.
Old Dec 31, 2002 | 08:37 AM
383LQ4SS's Avatar
Default Re: nitrous fuel pressure shut off
You could run a window switch to ensure its only activated at proper RPMs. You could also click on the Speedshop.Org banner on the right >>>> and check out there O2 shutoff switch. Essentially this will only allow you to spray if the AF ratio falss within a "normal" range. Pretty neat. The super expensive Venom kit has that feature.
Old Jan 16, 2003 | 01:34 PM
Humanoid's Avatar
Does this O2 cutoff switch work quick enough. I mean, will is shut off the spray b4 damage is done?
