Nitrous Outlet Puck Replacment :)
Old Sep 22, 2013 | 08:38 PM
OrangeChevyII's Avatar
Yes, they'll offer both carbed flanges for the plate kit.
Old Sep 22, 2013 | 11:12 PM
brandon6.0's Avatar
Damn man thats pretty impressive. What controller u run for your nitrous?
Old Sep 23, 2013 | 08:33 AM
The nos mini controller.
Old Sep 23, 2013 | 08:42 AM
dnkynrbk's Avatar
Originally Posted by OrangeChevyII
Yellow bullet guys are reporting 50-70 hp more over the Victor Jr intakes.
If you get some dyno #s between the two intakes
on a carb set we have only seen 15 to 20 hp difference between a mast and super vic. Im curious on efi set up.
Old Sep 23, 2013 | 09:08 AM
brandon6.0's Avatar
O ok. Need a controller but nit sure which to get. Heard good things about edelbrock controller. But a lil pricey tho.
Old Sep 23, 2013 | 09:25 AM
ATVracr's Avatar
Good luck with the new set up, looks badass!
Running 5.40's you already know whats up so my only suggestion is start low on timing with the 2nd kit. It brings the heat! (at least it always has for us. LOL !!)
Old Sep 23, 2013 | 02:47 PM
Baby steps for sure. The Ls3 still runs, it was just time to go faster.
Old Sep 23, 2013 | 06:10 PM
navyblueSS's Avatar
Nice!
Old Sep 25, 2013 | 02:43 PM
ShiznityZ28's Avatar
Originally Posted by Carter01
Please post up results. I am very interested to see the gains vs money spent on this switch. I am at the same point right now however I haven't convinced myself to go with a bigger built motor. You truck flat out works so I think this will be an excellent comparison.
there is no better upgrade than more CI with nitrous. trust me....
Old Sep 25, 2013 | 07:10 PM
Carter01's Avatar
I know Steve, makes we wonder if I should ditch the 408 idea and go bigger?
Old Sep 25, 2013 | 09:57 PM
I'm getting the heads tomorrow from the machine shop. It'll be running hopefully in the next few days.
Old Sep 26, 2013 | 08:57 AM
  #32
ATVracr's Avatar
408 goes mid 8's
Tall deck motor goes mid 7's
How fast do you want to go?
Old Sep 26, 2013 | 09:19 AM
  #33
Carter01's Avatar
Originally Posted by ATVracr
408 goes mid 8's
Wow, well you the answer to that question but my wife holds the check book! lol...
I need a racing partner to help fund half, any takers out there?
Old Sep 26, 2013 | 12:02 PM
  #34
87silverbullet's Avatar
I got ya back Andy. Just go find a 5.3 alum block. We'll send it to ERL.
That's my next step
Old Sep 26, 2013 | 02:36 PM
  #35
ATVracr's Avatar
That's my next step
ERL have a tall deck?
IF I were building another nitrous motor it would be a tall deck with a 4.375 crank. 480ci , mozez headed , sheetmetal, dry sump...Gangsta!
Old Sep 26, 2013 | 03:00 PM
  #36
X2... thats if i didnt have big money for a billet 500ci block. lol.
that setup above goes 7.4's on 2 .030 kits with some work @ 2900.
Old Sep 26, 2013 | 03:43 PM
  #37
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
The Nitrous Outlet puck worked absolutely flawless for me, unfortunately it wouldn't work in my Mast 2 piece intake.
That's unfortunate, thanks for sharing the useful info though...
-Garrett
Old Sep 26, 2013 | 03:44 PM
  #38
ERL does the tall deck thing with a spacer plate on a stock block that they have gone thru with new liners. It will end up at 482 cubes. 4.125 borex4.500 crank.
A done up built short block from them is $9900.00. That also includes a custom cam and 1/2 ARP head studs.
http://www.erlperformance.com/gm-ls-...i-short-blocks
Old Sep 26, 2013 | 04:19 PM
  #39
Carter01's Avatar
Man you guys got me drooling..... 450 plus ci is for me!
Alright Bobby, let's do this!!!!!
Old Sep 27, 2013 | 02:38 PM
  #40
brandon@nitrousoutlet's Avatar
I like where this is going...
