Anyone using methanol nitrous injection?
Old Jan 7, 2003 | 09:43 PM
Darren's Avatar
Default Anyone using methanol nitrous injection?
I ordered the new NX Direct Port System. I am running a seporate fuel cell and a low pressure system. I ordered the Holley Black Pump and Methanol safe regulator. I have Till the end of the month to decide which way to order the NX system. I would like Members with experence with Methanol to give there advice.
The car is a 98 TA with a 422 stroker, trans brake 350, 12 bolt 3.73 spool, and every other thing you can think of.
I just finished the engine, Its got stage 3 MTI heads and there biggest hyd roller, jesel rockers, Cosmetecs, Ported Holley/lingerfelter intake, 80mm tb. I spent 8 hours porting the intake to make it right. All I can say is this thing makes tons more power that it did on the LS6 intake. The Idle is much more stable and mid to upper RPM it Turns on. It made 505hp at the rear wheels before Now it will be dyno once We get 200 miles on it. I will bet it make 535hp or so.
I have concidered Methanol because of certain benifets, It makes more torque, Its less likely to detenate, It has a cooling effect. You have to run twice the amount. Its available around us here.
What might the negatives be? We will only be jetting up to 200 to 300 hp.
Thanks Darren <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Jan 8, 2003 | 12:47 AM
KTamez's Avatar
Default Re: Anyone using methanol nitrous injection?
Most people aren't big fans of using Alcohol for Nitrous System Enrichment. You mentioned alot of things that are true about its benefits, but there are a few issues that make it basically not worthwhile.
-Tuneability, Its harder to read plugs with Alcohol.
-Fuel Volume, It will take somewhere in the neighborhood of 1.6-1.8 times as much Alcohol (opposed to Gas) to achieve a "correct" Nitrous/Fuel Ratio. Personally I wouldn't use that pump even if I were using Gas, let alone Alcohol. I'd Prefer 2.5+ times the pressure at the pump as the system is flowed at. Look into a BG 280 at a Minimum, and would prefer a Magnaflow or Product Engineering Pump. This is for Gas. Alcohol? Plan on a BG400 or Pro Star 500. Fuel Pumps are my Pet Peeve on Nitrous Cars, put the biggest baddest pump you can on there. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
-Corrosive. Plan on rebuilding the fuel pump every year, and replacing the fuel lines every two years Minimum. Maybe longer if after use you drain and completely flush the system (This is taking into account a seperate fuel cell). Also Note that due to corrosion, you can create problems with lining in the hose, which in turn can create havoc with Solenoid(s) (Won't open/Close correctly), Nozzles and jets (Plugged).
-Trackside/Online/Phone Support, Minimal at best since you're dealing with a totally different animal then most people.
I've actually talked to Alcohol Injected Cars, using Nitrous that Use Gas on the Nitrous side of things.
Of anyone, Nitrous Express seems to have the most solid grasp of running an Alcohol Enriched N20 System.
Good luck with whatever you decide to do. I briefly looked into the same thing, for the same reasons you mentioned, but I'll be Running VP-NOS or Torco 116 NOS Gasoline. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jan 8, 2003 | 09:07 PM
Darren's Avatar
Thanks for the reply. I know about the corrosiveness of alcohol and what it does to most components it lives around. I raced carts for a long time and always had to flush with fuel before storing. I agree with what you have to say. When speeking to Mike at NX he told me about the 98 car he has there that they run on alcohol and even so he was not tring to convince me to go that way. Thats why I posted to see what other are doing. As far as the pump its what NX recommended I buy so I did. I have a Mallory 250 series pump I could put on it but I thougt it to be a bit over kill. NX said to run the pressure at 10psi. The Holley Black flow 140gph free flow and 120gph at 9psi. That Equals to 720lbs per hour. That will support as much nitrous as I want to run. I know Its not pretty but it is dependable. That I know, I have some holley pumps that have lasted for years of daily driving.
Later Darren
Old Jan 9, 2003 | 12:21 AM
KTamez's Avatar
I can't argue with what Mike Wood has to say (at least you talked to THE man on Nitrous/Alcohol relations).
Like I said fuel pumps are just my pet peeve. I've had good luck with Holley Red Blue and black pumps in tyhe past, though I've just never used them on a Nitrous Enrichment system.
My main issue with it is initial Pressure drop. I really like the Magnaflow pumps that put out somehwre in the neighborhood of 30psi at the pump. For an NX system flowing at 10psi, you'll have all the volume in the world, but with enough pressure so that when the solenoid(s) open, you aren't going to see any issues.
All JM humble worthless opinion. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Kurtis
Old Jan 9, 2003 | 05:37 PM
The Guy in MY 99TA's Avatar
Ya ever looked inside an alky motor? I have a freind who runs one and they CANNOT be sat up for over a week or so. He crunk it up for me when he first put alcohol on the car and we pulled valve covers and condensations was EVERYWHERE. I like the way alcohol cars run but I can't see myself doing it.
Josh S.
