Block Strength for 300 Shot
Old Oct 16, 2013 | 03:11 PM
TurbopigB4C's Avatar
Default Block Strength for 300 Shot
On an iron block 5.3 if I plan on using a 300 shot should I stay with the small 3.800 bore and 4.0 stroke for a 363 or is the block still strong enough when bored 3.903 for a 383? On a 300 shot in an iron block do I need to do 1/2" head studs or are the stock size head studs sufficient?
Old Oct 22, 2013 | 09:34 AM
Noyzee's Avatar
8 second mod
do a little search. all this info has been discussed besides maybe the block part with a 5.3
hard to say for sure but i would say you should be ok as long as everything is tuned right.
Old Oct 22, 2013 | 08:44 PM
WhiteLTone's Avatar
i sprayed 300+ with 5.3 block, stock replacement arp head bolts, ls9 head gaskets. 1/2" head studs arent needed if you can keep the tune up in check. this was with a 3.905" bore and stock ls1 crankshaft.
