Tapping NX Shark Nozzle on TR MAF End
Old Jan 19, 2003 | 06:46 PM
broke7's Avatar
Default Tapping NX Shark Nozzle on TR MAF End
I have an extra TR MAF end here. The guy shorted me on the nozzle adapter and havent gotten around to ordering one yet. I was thinking about tapping the maf end for my spray near the edge about 1 inch back.
Although I need some feedback on whether you guys think the nozzle would be close to the mas metering portion and would effect the mas signal.
This will of course be tapped after the mas meter not before. I see guys spraying dry shots through the airbox so assume it would work.
This is wet kit though.
Thanks
Old Jan 20, 2003 | 09:17 AM
Black Sunshine/ 00SS's Avatar
Default Re: Tapping NX Shark Nozzle on TR MAF End
That will be fine. I have mine set up like that. Drilled and tapped the hole, right behind the MAF. No problems, as long as the seal is good, and you have the spray directed towards the TB. Good luck.
