new to nitrous need some help
Old Oct 30, 2013 | 09:31 AM
rlabar01's Avatar
Question new to nitrous need some help
i have a 94 z28 ( lt1) mostly stock...
i want to spray 150 shot wet nitrous
i have a bottle, brackets, a intake elbow with a 6an jet fitting already in the casting. i will be purchasing a WOT switch, remote bottle opener, blah blah blah.
my biggest concern is how can i retard timing without having two tunes? i read up as much as i could on the MSD 6al box with a timing retard attachment. wich seems like it would work, but do i need a blaster coil, and an adapter harness etc. to run this set up?
i looked at the mallory 685 ignition but couldnt find alot of detailed info on the product.
whats the easiest way to pull a few degrees of timing with these lt1's?
Old Oct 30, 2013 | 12:51 PM
dekan513's Avatar
not sure on the lt1 but i know alot of ls ppl use the home made resistor trick. might check on that.
Old Oct 31, 2013 | 05:09 PM
brandon@nitrousoutlet's Avatar
The MSD and the Mallory are both good choices! The blaster is just a stronger coil over the factory unit.
