Mistakes you made
Old Nov 20, 2013 | 07:28 PM
sinisterC4's Avatar
Default Mistakes you made
Never used nitrous before, just received a plate system from Nitrous Outlet and starting to install it. What mistakes or lessons learned while starting out? What would you have done different? Basically have a lc1, lnc 2000 and a NOS mini to install and not in a big hurry to install.
Old Nov 20, 2013 | 07:41 PM
HCI2000SS's Avatar
I can't say that I really made any mistakes that I really regreted to much, I went the extra mile with a good custom tune, and all the proper accessories and whatnot, so I could enjoy it reliably and safety. The wiring was really the hardest part to me though
Old Nov 20, 2013 | 09:13 PM
danger ds's Avatar
wiring was the hardest part for me. One change I made that I wish I would of done in the beginning was wire in the WOT position wire into my PCM instead of using the micro switch on the TB.
Old Nov 20, 2013 | 10:12 PM
BAKED's Avatar
Not going turbo sooner lmao!
Old Nov 20, 2013 | 10:15 PM
BAKED's Avatar
My advice is to learn how nitrous really works. Learn how to read plugs, and buy quality parts.
Old Nov 21, 2013 | 01:18 AM
Caribe's Avatar
Mistake= Not labeling what wire went to what.
Old Nov 21, 2013 | 01:16 PM
ShiznityZ28's Avatar
label whires and pay attention to where you run them. Keep them away from power,heat and sharp metal. GEt a good tuner to show you how to tune the car and learn how to read plugs. if a tuner tells you that reading plugs is not needed get a better tuner.
Old Nov 21, 2013 | 01:50 PM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
This, let us know if you need some help reading plugs! A tune is important also, for anything 100 shot or over. Cooler plugs, adequate timing pulled, 93 octane as a minimum, and you are ready to rock and roll!
-Garrett
Old Nov 21, 2013 | 06:43 PM
87silverbullet's Avatar
Mistakes: Not listening to the big guys here such as Shiz and ATV. They beat me up about on here awhile back when i showed the pics of the,motor and the aftermath.
Some of the other guys in here to listen to: carter01, firehawk441, camscam, shortdog, minytryker, and there are a few more here that i can't remember, but you will know when theypost up. There is no reason to burn a motor down with all the guys on here that can help you
Old Nov 21, 2013 | 09:08 PM
sinisterC4's Avatar
Thanks I'll read up on it.
Lol I'm finishing up a turbo project now. Wiring clutch and a few sensors install and its done.
Wiring isn't to hard for me....only if I understand it. I do have HP tuners on my list. Guy that has tuned my car , I have no worries. I'm sure he will help if I have problems but he can't babysit me
-Garrett
93 always
