seperate fuel system for nitrous.
Old Feb 1, 2003 | 11:34 PM
TApimp's Avatar
Default seperate fuel system for nitrous.
what are you guys using as a seperate system for a nitrous kit? what kind of pumps? fuel cells and what not. i am a using the nossle kit from holley, and they suggest i run a seperate fuel system for going over a 300 shot. this is on a 400+ CI motor.
Old Feb 1, 2003 | 11:35 PM
TApimp's Avatar
Default Re: seperate fuel system for nitrous.
also what kind of injectors should i use?
Old Feb 3, 2003 | 01:38 PM
Reckless's Avatar
Super Moderator
Separate fuel systems are typically for direct port applications (conventional). The NOZsle kit feeds directly off the stock fuel system as far as I know. If so, you will need some pump upgrades. Injectors are only a factor if you are running a dry kit (overtaxes the injectors). Here's the system I am working on:
www.cofba.org/users/reckless/dp_fuel.html
www.cofba.org/users/reckless/dp.html
