need help with window switch
Old Feb 6, 2003 | 02:45 PM
98Blubrd's Avatar
Default need help with window switch
I just got my harlan window switch. i have a fuel pressure safety switch and i was wondering where to hook the relay (white wire) on the window switch to. before the fuel pressure safety switch or what. on the instructions it says do not hook up to seloniods or it will fry the window switch. please help asap i want to install this thing tonight. thanks.
Old Feb 8, 2003 | 07:28 PM
LS1Formula98's Avatar
Default Re: need help with window switch
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by TransAmJo:
<strong> I just got my harlan window switch. i have a fuel pressure safety switch and i was wondering where to hook the relay (white wire) on the window switch to. before the fuel pressure safety switch or what. on the instructions it says do not hook up to seloniods or it will fry the window switch. please help asap i want to install this thing tonight. thanks. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I am not sure if it is the same, but when I installed my rpm window switch and my Fuel Pressure safety switch it went like this...
From the harness/relay, I connected the white wire (ground) to the connector marked "c" on the fuel pressure safety switch. Then, the yellow wire form (MSD window switch wich is open switch to ground)I connected to the connector marked "NO". BTW: My kit is a Nx wet kit and wire colors may vary. Also I have an MSD window switch instead of the Harlan wich wire colors may vary as well.
Old Feb 9, 2003 | 12:01 AM
Magyver's Avatar
My friend told me to get an MSD window switch for the NX kit I am buying. I've heard bad things about MSD, but he said it's because people are connecting it wrong. Something about the solenoid and relay. Can't remember exactly what he said, but what do yall use. The MSD window switch according to him cost about 60 to 70 bucks. This sounds good compared to NX's window switch that supposedly cost 279! What a huge differenc. Can yall give me feedback please.
Old Feb 10, 2003 | 03:25 AM
Jamie99TA's Avatar
Here is how I wired up my harlan window switch and it works perfect. I modfied the NOS diagram to include the window switch. It is small but readable.
<img src="http://web.tampabay.rr.com/jdeshong/NOS%205177%20Wiring%20Diagram.jpg" alt=" - " />
Old Feb 11, 2003 | 03:05 PM
RV's Avatar
RV
TTT...This has been holding me up for a little as well.
