2 soleniod, 1 relay
Old Feb 11, 2003 | 02:05 PM
ls1290's Avatar
Dumb Ass Vette Moderator
Default 2 soleniod, 1 relay
Can two soleniod wired in parallel be run through a single relay? TIA.
Old Feb 11, 2003 | 09:56 PM
Sears's Avatar
!Dial-up Director
Default Re: 2 soleniod, 1 relay
Yes, both solenoids are wired to one relay. With the relay NX supplied it was the green wire. Unless it is a purge solenoid where you would run one wire to ground and the other to a momentary switch.
Justin
<small>[ February 11, 2003, 09:57 PM: Message edited by: Jsears8 ]</small>
Old Feb 12, 2003 | 08:29 AM
ls1290's Avatar
Basically I would like to wire to purge solenoids to one switch. I figured that if I wire them together in parallel that that would do the job.
