Nitrous didn't hit...
Trick window switch set up: lock out first gear, spray 3600-6300 for 2&3.
Harris plate,heater working, bottle pressure good, purges, all connections and grounds appear ok. Only reason I know is car ran identical back to back times with it off and on (1/8th mi). How can I check it in my garage? It worked on the dyno during tuning a month ago....
1. all fuse locations related to components/function in question
2. All grounds
3. Power leads
4. Start assesing actual electronic components relays ect..
Dont assume things are ok because they were fine in the past. verify with a volt meter and be sure of what your working with its easy to be chasing around replacing fuses and swaping relays and such only to discover after hours it was something simple like a bad ground or swich.
1. Disconnect the nitrous and fuel from the solenoids.
2. Lower your window switch settings to activate as low as possible.
3. Put your hands on then while you have someone rev the motor to the activation RPM.
You will feel the solenoids "click" at the RPM activation point if there isn't a problem. If you don't feel them clicking do as stated above and get your volt meter out and start chasing down a wiring issue or window switch issue.
Keep em coming...hope to have someone that knows more about wiring (def my weak point) to help me sort this out soon.
