HOT: NX kit relay wiring... which wire is which???
Helping a friend install his NX wet kit on his LS1 right now out in the garage. On the relay, we've got a red, green, white, and black wire. We've already figured out that the green wire splits off and goes to both solenoids. We are pretty sure that the white wire is the ground. But could someone please confirm what the other three wires are for sure? TIA! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<small>[ February 17, 2003, 08:05 PM: Message edited by: BriGuy ]</small>
Green - solenoids
Red - arming device
Black - 12 volt +
White - Ground (or fuel press. switch if you have one)
Just ot let you know, all NX instruction are online at http://www.nitrousexpress.com/instal...tallation.html
Justin
<small>[ February 17, 2003, 08:20 PM: Message edited by: Jsears8 ]</small>
Red - arming device
Black - 12 volt +
Justin
Thank you so much for your help!
For some reason my computer either can't or will not download the instructions for me to be able to read them. Once again thank you!
No prob. You will need Adobe Acrobat to view the instructions b/c they are in .pdf format.
You can get it here
http://download.com.com/3000-2378-10...ml?tag=lst-0-1
NX provides great instructions.
You can get it here
