C5 nitrous guys come on in
Old Jan 19, 2014 | 08:45 PM
dsadsdaiouser's Avatar
Default C5 nitrous guys come on in
For those of you with nitrous on your C5s where under the hood are you mounting your LNC box? We also have a NOS RPM activated box to mount. They're both small and thin but I want to make sure the hood doesn't hit them when they're closed.
If you had pictures that would be very helpful.
Thanks.
Scott
Old Jan 19, 2014 | 09:57 PM
mcshocks's Avatar
The NOS window switch I'd mount in your glove box, real easy to get wiring into there behind the battery. The LNC mounts easily inside the battery box area.
Old Jan 19, 2014 | 10:09 PM
igtabg1's Avatar
Lnc velcro'd on the side of the fuse box ... its great.
Old Jan 20, 2014 | 07:19 AM
Thanks guys. Does anyone have any pictures?
Also, I believe I need a power source under the dash for the switch and one in the engine compartment. What are you guys using for these two sources?
Scott
Old Jan 20, 2014 | 06:43 PM
mcshocks's Avatar
Add a fuse on a switched source at the fuse box in the passenger footwell to a relay or two powered off the battery works. Really easy to wire in these cars from the passenger footwell to the engine compartment from right behind the battery.
Old Jan 23, 2014 | 08:39 PM
billymz28's Avatar
mounted mine inside the battery divider tried velcro at first but didnt hold so put a couple screws to it.
