Am I missing anything?
Want to run a nitrous setup over spring break, and I've been doing some research. I've decided I want to go with a dry system. Just making sure i'll have EVERYTHING I need to do the install myself, so if you have anything to add to the list please let me know.
nitrous solenoid
-4an line (how long if I run from spare tire inside the car to the nozzle?)
fan nozzle
jets
10 lb. bottle
relay and switches
a/f gauge
remote nitrous pressure gauge
a-pillar dual pod
bottle warmer
remote opener
window switch
momentary switch
I want to somehow mount a switch to the shifter and run the system off of that instead of a WOT switch. What kind of mounting brackets will I need for the solenoid and bottle if any? I want to mount the bottle in the spare tire compartment.
Where do you all recommend I look for some of these pieces? I might buy some of it used but I feel safer buying the solenoid new. Also, as this is my first kit, where can I go to find some information on how to wire everything?
Thanks and sorry for the long post.
nitrous solenoid
fan nozzle
jets
10 lb. bottle
relay and switches
a/f gauge
a-pillar dual pod
bottle warmer
remote opener
window switch
momentary switch
Just call the Nitrous outlet>>>
You may need a few more fittings and such here and there but its hard to say without an inventory of exactly what you have already. Anyways...click the link on the right for The Nitrous Outlet and talk to those guys.
And if you go to NX website they have wiring diagrams for all thier kits. Just eliminate the fuel noid since thiers are all wet kits.
