10-bolt + nitrous from a roll, safe??
Old Mar 2, 2003 | 07:16 AM
Gregg 00SS's Avatar
Default 10-bolt + nitrous from a roll, safe??
I've been against getting nitrous due to need of getting a new rear, which I can't really afford right now. Just rode in my buddies A4 Z28 with nitrous and now I'm more interested. I know from a dead stop, I'll blow the rear if I spray, so that's not even an option. But can a 10-bolt take it from a roll? I'm guessing I probably wouldn't spray until 2nd. Probably be between 100-125 shot. Is this borderline to 10-bolt survival, or would I be fairly safe doing this?? Also, I have pretty much all bolt ons to include a T1 cam.
Old Mar 2, 2003 | 02:35 PM
CAT3's Avatar
Restricted User
Default Re: 10-bolt + nitrous from a roll, safe??
Greg, watch the frost heaves there in the lower AK, I would be more worried about hitting one and messing up a rear axle form the hop (used to livein Fairbanks 96-00). NEway, I have ran a 100shot and sprayed right out of the hole on quite a few bottles, no problems. Not to say that is the norm, but there are several of my friends that race the same way with the 10bolt. You have to be a little more concerned when using an M6 vs the softer shock with an A4 (at least if you have a good clutch that is). Just juice it already and No hitting Moose. Good-luck, Charlie.
