nitrous fuel pressure question (pic)
Old Feb 8, 2014 | 08:38 AM
dsadsdaiouser's Avatar
Default nitrous fuel pressure question (pic)
Finished installing all of our nitrous parts other than the wiring and started it this morning to check to check for leaks. I don't have fuel pressure on the gauge. Bad gauge? Did I install something incorrectly? All I did was unscrew the plastic cap on the end of the fuel rail and screw the manifold on as seen in the picture. Gauge is reading zero when I start the car.
Oh, by the way, the FPSS is coming out the bottom of the log from the other 1/8" port.
Scott
Old Feb 8, 2014 | 09:42 AM
streetlegalls1's Avatar
You have to remove the Schrader valve behind the plastic cap you removed
Old Feb 8, 2014 | 02:39 PM
Thank you. I'm new to the LS1 and thought there was something that I was missing. I appreciate it.
Scott
Old Feb 8, 2014 | 06:39 PM
any time
