window switch?
Old Mar 4, 2003 | 09:15 AM
sal346's Avatar
Default window switch?
i know its a stupid question, but i dont know alot about n20 system and i cant find out what this is, is it a WOT switch or a TPS switch, i know alot of u said u need it when running n2o and i wanted to know what it is exactly, thanks
Old Mar 4, 2003 | 09:53 AM
SStillSSmokin's Avatar
Default Re: window switch?
It's a switch that will turn your nitrous flow on, then off at preset rpm's. That way your juice will only be on when you want it. For example, most people suggest,and set their window switch to allow the juice to come on @ 3000 rpm, and then shut off just before your rev limiter, that way if you miss a shift you won't be spraying while your motor is bouncing the rev limiter(which would be very bad!!!) <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Old Mar 4, 2003 | 10:41 AM
sal346's Avatar
thanks for the reply that answers alot for me
i might be considering n2o soon since its cheaper than a supercharger, i was hoping a 100 wet shot could get me into the low 12's
Old Mar 4, 2003 | 01:34 PM
Bad Habit Bird's Avatar
What kind of times are you currently running?
