nos kit for a lt1 and ls1
thanks for the help
Bottle, main feed line, noid, (second noid in series, reccomended) line, and then a nozzle.
a switch is needed to activate the system, i reccomend a WOT switch, but some use a button instead, (i dont reccomend that)
you will need a arming switch, any simple switch will do.
And you will need a standard automotive relay.
If your want to spray a larger than 65hp shot, its reccomended to get 2 nozzles, and a Y adapter. (this is how the 5177 NOS kit for the LS1's works)
I am not too familar with the dry setup from the LT1, but i do know for sure it has the basics that are needed. Im fairly sure it has a fuel pressure vacuum controled device, but that is not needed on a LS1 kit, you just simply spray before the MAF, and it will pick up the extra airflow, and the computer should compensate for the rest. (this is how the 5177 LS1 NOS kit works)
Ryan.
