Mallory 685 Ignition or just a window switch?
Old Mar 9, 2003 | 12:07 AM
vendela99's Avatar
Default Mallory 685 Ignition or just a window switch?
Okay, I bought a Mallory 685 because it has lots of goodies including a window switch, but I'm not sure if its even compatible with an LS1...does anyone know? If not, would I be fine just going with the stock ignition and a window switch? Also can I adjust the retard on the stock ignition?
Old Mar 10, 2003 | 03:43 PM
383LQ4SS's Avatar
Default Re: Mallory 685 Ignition or just a window switch?
<img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
OMG....I think Ive seen a ghost <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" /> Chris Spiess is alive!! <img border="0" alt="[gruffy cottonball]" title="" src="graemlins/gr_gruffy.gif" />
<small>[ March 10, 2003, 03:44 PM: Message edited by: 383LQ4SS ]</small>
Old Mar 11, 2003 | 12:20 AM
Chris Spiess's Avatar
LS1s are a distributorless coil-on-plug ignition, and arguable as good as any typical aftermarket ignition. The Mallory is not compatible. A window switch is fine. Timing functions are controlled by the computer and can be adjusted with LS1Edit.
Old Mar 13, 2003 | 12:37 AM
Yeah, had a couple setbacks in the fall and got out of the usual routine, but I'm starting to get back to the usual routine.
