3600 Vig and NX wet kit?
<small>[ March 09, 2003, 08:49 AM: Message edited by: PlowTown Missile ]</small>
just my .02
Josh S.
I'm not exact on the Rev limiter, but if memory serves me right, it's at 6600 or 6700. I do spray it right out of the hole., and have had no problems hitting the limiter.
I did have problems initially, hitting the rev limiter, when I changes the rear gears, and raced without changing the gear settings in the computer, but that went away, after changing the gear setting with LS1 Edit.
If this is not a good nitrous convertor, I wonder what I would have ran with a better convertor? #'s on the dyno and a 100 shot showed 471/555 HP/TQ. Are the times comparable to what others have seen with similar dyno #?
