Nitrous kit questions with blown motor
Also they took it to a shop and said the 7th cylinder was cracked. The seller didn't seem to know to much further than what the shop said so it could be less or more. Can I confirm this without ripping it apart. Maybe drain the oil see if there any pieces of metal?
The easiest way to tell if it is a wet kit is to look and see if there is a line from the schrader valve at the front of the passenger side fuel rail. I don't think these particular kits came in a "wet" version.... IIRC.
As far as #7 being "cracked" did he say if it was a cylinder sleeve, the head, piston or anything? "cracked" could be a lot of things.
The seller did mention the sleeve he didn't seem to know anything other than what they told him he said it was at the shop for over a month. Told me the shop didn't seem like tthey knew what they were doing. Gave him a price to fix and then it sat. How can I go about verifying if it's the sleeve?
N2
