Nitrous install issues :( Help!
Old Mar 12, 2014 | 12:28 PM
Rise of the Phoenix's Avatar
I'd take it to a different place then. You can fit a bung in anywhere along the header collector.
Old Mar 12, 2014 | 02:07 PM
Jarren_b's Avatar
Not really.. My oil pump makes it a very tight space
Old Mar 12, 2014 | 02:08 PM
Jarren_b's Avatar
I mean oil pan
Old Mar 17, 2014 | 07:17 AM
badbubba's Avatar
What gauge wire are you using and how long of a run? Especially the common ground wire. Everything crimped well or soldered?
Old Mar 17, 2014 | 07:23 AM
badbubba's Avatar
If you can weld a bung near the collector, keep it on the upper part of the pipe. If placed on the lower area, condensation will run down on the sensor and kill it.
