What is meant by dual stage???
Old May 14, 2004 | 02:00 PM
Just Floor It's Avatar
Default What is meant by dual stage???
Ok, when someone says "dual stage" in reference to Nitrous, what does it mean??
Im a when it comes to nitrous so.....
Thanks
Old May 14, 2004 | 03:11 PM
SilverGhost's Avatar
Motorboater
just like what it sounds essentially. typically one stage outta the hole then another after that. lot of guys hit it with a dry kit, like 100 hp outta the hole, then smack it with whatever they want on top of that with a wet kit right after..
kinda like having two kits on the car..seperate selenoids, lines, jets of course, etc
Old May 14, 2004 | 04:10 PM
Slow Z28's Avatar
alot of people run it this way so they aren't hitting the tires with the full amount of nitrous they want to run right off the line. almost a pseudo progressive controller because you have the lower amount off the line that you can hook that much power and then the extra amount you can set it at a certain point to come on and get the full blast.
Old May 14, 2004 | 05:43 PM
BMN's Avatar
BMN
2 nitrous kits on the same motor. That easy.
Old May 15, 2004 | 12:55 PM
PREDATOR-Z's Avatar
1- You push button #1
2- you push button #2
oh I forgot, "hold on"
