Spray on a H/C car Q's
Old May 15, 2004 | 11:43 AM
v8maro's Avatar
Default Spray on a H/C car Q's
I currently have my car tuned for an N/A setup. If I wanted to do a 100hp spray, would I need the car re-tuned to lower timing & bump up the fuel? Would this only be the case with a dry kit? Should I go with a wet kit for my needs? I will probably be spraying 150 in the future.
Anything I should know before going down this rout?
What rpm's should I spray at?
I was looking at the TNT 100 shot F1 kit, I kinda like that, any good?
thanks guys
-Steve
Old May 15, 2004 | 12:02 PM
ITSovr4U's Avatar
thanks guys
-Steve
I had my MSD window switch set at 3000 to 6800 and the rev limiter was at 7000. I had the 100 NX wet kit on my H/C C5 that had 427RWHP N/A and went 11.54 N/A and 10.64 @ 129MPH on the 100 shot. I didnt change the tune or timing and had no problems. If you are using the wet kit it will add its own fuel the injectors will not play a part in it. If you plan on going 150 shot you may have to change your fuel pump and take out some timing. I do not know what my timing was set at however. This was just my experience and my opinion based on my car, Hope it helps.
Regards,
John
Old May 16, 2004 | 01:39 AM
v8maro's Avatar
Yes that does help! What kind of setup were you running then?
Old May 16, 2004 | 01:32 PM
Ed Blown Vert's Avatar
You are suppose to pull back the timing a bit on the nitrous.
I ran a 150 shot on my H/C's and kept the timing the same. I made sure it was on the rich side when I sprayed.
Old May 16, 2004 | 07:41 PM
ITSovr4U's Avatar
What do you mean by set up???? If you mean nitrous it was a NX Express single 100 shot wet kit. If you are talking motor it was tea 5.3 S2 heads and a 224, 581 cam on a 112 or 114 im not sure. On a stock bottom end.
Old May 17, 2004 | 08:01 AM
v8maro's Avatar
Did you blow the motor or did you just want more power? Is that why you went to the 408? I plan on spraying a 100wet shot on my stock bottom end H/C car, just wondering if it can take it?
-Steve
Old May 19, 2004 | 06:58 PM
ITSovr4U's Avatar
-Steve
I took the motor out it didnt blow. I wanted more CI and Iron block so i could spray more and go faster
Old May 19, 2004 | 08:16 PM
v8maro's Avatar
HAHA, cool, I plan on doing that later down the line, just want some descent numbers for now.
-Steve
