Do i need to use blow down tube???
Old Mar 27, 2003 | 10:13 PM
1Nasty Hawk's Avatar
Default Do i need to use blow down tube???
Just got my nos 5177 kit, one problem.. i dont know if the blow down tube will work with where i want my bottle.. Can i just use the cap that came over the valve to just keep it capped off??? Please respond,, Thanks.
<small>[ March 27, 2003, 10:14 PM: Message edited by: 1Nasty Hawk ]</small>
Old Mar 27, 2003 | 10:57 PM
JxxxOxxxE's Avatar
Default Re: Do i need to use blow down tube???
First, where are you trying to put your bottle? If you go to any NHRA sanctioned track, the tech probably won't pass you if you do not have a blowdown tube....
Old Mar 28, 2003 | 09:50 AM
ls1290's Avatar
Dumb Ass Vette Moderator
You do not have to use the tube 'as-is'. NHRA requires that the bottle have a blow off valve in which the gas is vented outside the car. I am not using the tube. I am using some -8an teflon hose that goes from the blow off valve to a hole in the trunk compartment. I have had no problems with tech inspection <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Mar 28, 2003 | 11:44 PM
When i go to cecil county racetrack they never do any type of car inspection.. Could i though just leave it capped off???
Old Mar 29, 2003 | 12:01 AM
NickMapleT/A's Avatar
You could leave it capped off if your track doesn't check for it, but it's always a good thing to have just in case. What if you go to a different track some day? I'm also wondering where you are trying to mount your bottle. The problem with the 5177 kit is that the bottle is too damn big. The only place mine would fit was the trunk. It's easy to mount the blow down tube in the trunk.
Old Mar 30, 2003 | 01:00 AM
kevinb's Avatar
Well, even if you could pass tech, if the valve popped and dumped 10lbs of nitrous into your car in an instant i know i would regret not having a blowdown tube. <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
