yank ss3600 with nitrous
I ran a 3600 with heads and cam and it worked well on motor but was a beast on spray because of it being tighter. A 4000 would of helped it on motor but I don't know if it would of coupled like that 3600 did on spray. Maybe shortdog can chime in and give a run down of what it pulls like on the back half of the track.
Did not find what I was looking for then started thread then searched again and found some stuff so my apologies on my lame search attempt
To answer your question though, sky is the limit with a direct port, or until you blow the motor. A plate shot will allow you to get pretty big with the jets but you have to have good tuning knowledge and read your plugs to make sure you are not running into distribution issues.
