NX MAF system questions....
Old Apr 17, 2003 | 08:38 AM
andy98Z's Avatar
Default NX MAF system questions....
I am planning on spraying about 250. What are the advantages of spraying dual stage MAF or spraying dual stage in the bellow beteen the maf and tb?
Does the MAF distribute the nitrous better?
Also being so close to the sensor wires would it cause them to pick up some readings and add extra fuel?
Old Apr 17, 2003 | 08:56 AM
Nitro Dave's Nitrous Outlet's Avatar
Default Re: NX MAF system questions....
The maf kit will spray a larger shot than the nozzle.If you plan on running a dual stage you can either use the SX2 nozzle or the maf kit.The maf kit will not affect your mass air meter any.
Both will work.The Maf kit is a cleaner look.
Dave
<small>[ April 17, 2003, 08:58 AM: Message edited by: Nitro Dave's Performance ]</small>
Old Apr 20, 2003 | 11:04 AM
02 Silver Z's Avatar
Whats up Andy? Is your motor done yet?
Old Apr 20, 2003 | 03:10 PM
Chad00ws6's Avatar
I have the MAF kit and I like it. I've only had a bottle through it so far but I'm considering maybe a dual stage with the controller.
It ran 10.53 @ 132.33 with a 1.461 60' on the 150 shot by itself and no controller yet. 3800lb race weight also.
