Nitrous kit almost complete
TNT F1 Wet
NX Bottle Warmer
NX Purge
NX Window Switch
MSD Window Switch with 3000/6000 pills
TR6 plugs @ .035
I have to send my window switch in to get it recalibrated for LS1, correct?
Now I need a timing controller. What do you guys recommend?
I want to reduce timing ONLY on the spray.
Also, I need a fuel pump. I currently have heads/cam that make 448rwhp, with a stock fuel pump, and stock injectors out of a 98 (I think they are 26#). Since I have a wet kit, I was told I don't need larger injectors, but I do need a larger fuel pump. I'm expecting ~600rwhp. Can someone recommend a fuel pump for me? Will the Walbro 340 cut it? Anything better?
Thanks guys!
Fuel pump...either the Racetronix single intank or get a good Walbro 255lph and wire it with a relay off the battery/alternator.
<strong> The Ramchargers timing tuner is currently your only option for timing controls. You can set timing for motor as well as pull some out on juice. It also has a built in window switch so you wont need the MSD.
Fuel pump...either the Racetronix single intank or get a good Walbro 255lph and wire it with a relay off the battery/alternator. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Is that Ramchargers timing tuner the same one as on tbyrne.com under nitrous?
Will the 255 be enough?
How difficult is it to get the 255 in our fuel tanks? i heard we need to drop the rear end to get to it!
Where can I find the racetronix?
Thanks!
