Shark nozzle vs dynotune plate
Old Jun 1, 2014 | 08:29 AM
99french's Avatar
Default Shark nozzle vs dynotune plate
Has anyone switched from one to the other or have comparisons between the two. I have both hanging out in my garage and can't figure out which is best to use. The plate only has one hole for the n2o and fuel to glow from. I'm only going to spray a max of 150 but will start at 100 shot. I will also be using a stand alone with c16 or dome sorta dedicated n2o fuel in it at 7-10 psi. So what is everyone thinking
Old Jun 1, 2014 | 07:57 PM
jblankenship's Avatar
I really don't think you will see much difference between either.
Old Jun 2, 2014 | 09:08 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
I'm sure that either setup will work fine, on 150hp. If you have any jetting questions for the nozzle or any other questions, let me know.
-Garrett
Old Jun 2, 2014 | 09:54 AM
99french's Avatar
I didn't think there would be but just wanted to get the most out of what I do have. Anyone else have some feed back?
